I have installed the ArcGIS Solutions add-in to ArcGIS Pro 2.4.2, so that I can modify the domain of my hosted feature service on ArcGIS Enterprise Portal 10.6.1.
Here are my steps:
- In ArcGIS Pro, I add my HFS to a new map from My Content (this confirms I am signed in as the owner)
- Launch ArcGIS Solutions
- Click 'Sign in to ArcGIS Organization > Finish
- Click 'Configure an ArcGIS Solution' > Next Step > Skip (do not need to add any new fields)
- In the 'Modify Domains' window, I select the layer from the drop down list > this loads the fields in the 'Field's drop down list. However, I get a red X in the Input Layer or Table saying Error Unable to connect to the Hosted Feature Service (see attached)
I am not sure why I am getting that error - I even tried in step 4 to add a field and it successfully added a field, so it shows that it was able to reach out to the hosted feature service.
I also repeated the same steps for an ArcGIS Online hosted feature service, and I was able to successfully run the tool to modify domains.
Any ideas?
Thank you,
Peggy
