First of all I'm new on Arcgis so maybe I'm doing something wrong.
I'm trying to load a simple shapefile with three points creating a triangle:
{"Coordinate":0,"longitude":37.665884,"latitude":-5.5233364},
{"Coordinate":1,"longitude":37.666139,"latitude":-5.5217056},
{"Coordinate":2,"longitude":37.666886,"latitude":-5.5220704},
{"Coordinate":3,"longitude":37.665884,"latitude":-5.5233364}
I have generated from PHP a shapefile with the previous information and also created a .prj, .dbf, .shx and add them in a zip file.
When I try to use the option load a layer from a file and upload the zip file attached, I receive the following error (sorry it is in spanish)
No se puede importar este shapefile. (Error HRESULT E_FAIL has been returned from a call to a COM component.)
I've tried to look at the forum and find some information about this error, but it seems that is a general error.
Any idea of what I'm doing wrong? I can use other tools to open the shape file (if needed i will tell you the name of the other product), but not on arcgis.
Thanks.
