Using ArcGIS JavaScript API 3.19 I am trying to do a bulk reverse geocoding like
<SPAN class="keyword token">var</SPAN> locator <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Locator</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fdummydomain%3A6080%2Farcgis%2Frest%2Fservices%2FTestGeocoder%2FGeocodeServer" target="_blank">http://dummydomain:6080/arcgis/rest/services/TestGeocoder/GeocodeServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> points<SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"x"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">83.000369</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"y"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">40.055185</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"x"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">83.000031</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"y"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">40.051250</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
locator<SPAN class="punctuation token">.</SPAN>outSpatialReference <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> options <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>addresses<SPAN class="punctuation token">:</SPAN> points<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
locator<SPAN class="punctuation token">.</SPAN><SPAN class="token function">locationToAddress</SPAN><SPAN class="punctuation token">(</SPAN>options<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I am not getting any error on page but the map screen looks empty! can you please let me know what I am doing wrong? and how I can export the points address to console? Thanks
