I have a table being returned from the Network Analyst OD Cost Matrix...I want to convert the result object to a GDB Table and I tried using this..
ODCM_Table = arcpy.na.Solve(outNALayer) #Solves the Origin-Destination Cost Matrix and produces the ODCM_Table
arcpy.TableToTable_conversion(ODCM_Table, workspace + "\Default.gdb", "ODCM") # Thought this should convert result to GDB Table
But it throws an error:Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\conversion.py", line 1904, in TableToTable raise e ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Input Rows: Dataset GPL0 does not exist or is not supported Failed to execute (TableToTable).I thought maybe the cause of the error was the formatting of the result object being held on the 'ODCM_Table' variable, so I printed it to see what it returns...
print ODCM_Table
GPL0
No problem I can see there.So how can I convert this result object to an actual table?
