I am using a Python script to query an ArcGIS Online feature service, and then I want to create records in an on-premise feature class based on the results. I've done this many, many times with point features, but never with polygon features. I cannot seem to figure out how to create a polygon shape from the JSON parameters (coordinates/rings).
for feat in agolQueryJson['features']:
feature_coords = feat['geometry']['rings']
For the first record, the value of feature_coords is as follows:
[[[3119080.82716037, 10062393.2323891], [3119167.33715791, 10062378.1910806], [3119165.12029902, 10062150.6820212], [3119136.04194509, 10062115.4521047], [3119109.98523858, 10062106.2047479], [3119106.03478733, 10062060.0765594], [3119080.82716037, 10062393.2323891]], [[3119080.82716037, 10062393.2323891], [3119079.78123078, 10062393.4141472], [3119079.72545653, 10062407.7937117], [3119080.82716037, 10062393.2323891]]]
I have not figured out how to take this and turn it into a polygon shape that can be used in an insert cursor. I've tried using arcpy.AsShape and just arcpy.Polygon, but no luck with either method:
poly = arcpy.AsShape(feature_coords)
poly = arcpy.Polygon(arcpy.Array([arcpy.Point(*coords) for coords in feature_coords]))
Any suggestions would be most appreciated!
