This script works great in ArcMap, updating the field EditField. However when I create a geoprocessing service from the result and run it, the field does not get update, although I get no error messages when running it. Does anybody would have any idea why the field would not get updated with the geoprocessing service? Thank you# -*- coding: utf-8 -*- # --------------------------------------------------------------------------- # calcfeatures_script.py # Created on: 2013-09-30 15:22:46.00000 # (generated by ArcGIS/ModelBuilder) # Usage: calcfeatures_script <Selecting_Features> <value> # Description: # test # --------------------------------------------------------------------------- # Import arcpy module import os, sys, arcpy, traceback, arcgisscripting # Script arguments Selecting_Features = arcpy.GetParameterAsText(0) value = arcpy.GetParameterAsText(1) Stewardship = arcpy.GetParameterAsText(2) arcpy.AddMessage("TEST") arcpy.AddMessage(value) # Local variables: Input_Points = Stewardship #Final_Output = value Input_Points_Layer = "SamplePoints_Layer" # Process: Make Feature Layer arcpy.MakeFeatureLayer_management(Input_Points, Input_Points_Layer) # Process: Select Layer By Location arcpy.SelectLayerByLocation_management(Input_Points_Layer, "INTERSECT", Selecting_Features, "", "NEW_SELECTION") # Process: Calculate Field with arcpy.da.UpdateCursor(Input_Points_Layer, ("City")) as rows: # row comes back as a tuple in the order specified here, so Office is row[0], Forester is row[1] for row in rows: row[0] = value rows.updateRow(row)
