Brached from https://community.esri.com/thread/95403
Hi Xander Bakker
I have also run your multiple raster percentile code. It runs upto loading the created polygon file:
execfile(r'F:\\data\\UAV\\Lodging_model\\GeoDatabase\\raster_percentile.py')
Processing Raster 'after_raster'
- Processing polygon: 0
- ExtractByPolygon...
- saved raster as ras0pol0
- fill dict with Value x Count
Runtime error
File "<string>", line 1, in <module>
File "F:\\data\\UAV\\Lodging_model\\GeoDatabase\\raster_percentile.py", line 171, in <module>
main()
File "F:\\data\\UAV\\Lodging_model\\GeoDatabase\\raster_percentile.py", line 67, in main
dct = {row[0]:row[1] for row in arcpy.da.SearchCursor(outname, flds_ras)}
RuntimeError: cannot open 'ras0pol0'
here is the first part of the code:
import arcpy
import os
def main():
# settings
ras_ws = r"F:/data/UAV/Lodging_model/GeoDatabase/raster/" # input raster workspace
fc = r"F:/data/UAV/Lodging_model/GeoDatabase/Hermitage_Lodging_Grid.shp" # input polygons
tbl = r"F:/data/UAV/Lodging_model/GeoDatabase/raster/Zonal_Perc_A" # output related table
lst_perc = [2, 5, 10, 90, 95, 98] # list of percentiles to be calculated
fld_prefix = "Perc_"
fld_poloid = "POL_OID"
fld_rasname = "RasterName"
not sure why it cant load the ras0pol0 ? It opens in acrgis no p[roblem from the geodatabase...
cheers
adnries
