Hello, I don't seem to be getting the CreateReplica_management call to work. It produces an error:arcgisscripting.ExecuteError: ERROR 000582: Error occurred during execution.Failed to execute (CreateReplica)The code being used is below. Any help here would be much appreciate by this newbie python person... import arcpy
from arcpy import env
import arcgisscripting
env.workspace = "C:\Documents and Settings\longs\Application Data\ESRI\Desktop10.0\ArcCatalog\SpatialVegMgmt_NT38.sde.DEFAULT"
tableset = "Actions, BioAgents, Density, Directions, Inspectors, MethodContacted, ROW, Units, weedFollowups, Weeds, WeedTypeRelate, WeedTypes, VegetationMgmt.GIS_SDE.weedIncidents"
replica_type = "CHECK_OUT"
output_workspace = "c:\usr_proj\ArcGIS\FileGeodatabases\Weed\Mark\WeedIncidents_FileGDB.gdb"
replica_name = "MarkReplica"
access_type = "FULL"
initial_sender = "PARENT_DATA_SENDER"
expand = "USE_DEFAULTS"
reuse_schema = "DO_NOT_REUSE"
get_related = "GET_RELATED"
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.Actions", "Actions", "AID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.WEEDFOLLOWUPS", "WEEDFOLLOWUPS", "ObjectID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.Density", "Density", "DID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.Directions", "Directions", "GDID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.Inspectors", "Inspectors", "IID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.MethodContacted", "MethodContacted", "MCID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.ROW", "ROW", "ROWID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.Units", "Units", "UID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.Weeds", "Weeds", "WID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.WeedTypeRelate", "WeedTypeRelate", "ObjectID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.WeedTypes", "WeedTypes", "WTID > 0")
arcpy.MakeTableView_management("Database Connections\SpatialVegMgmt_NT38.sde\VegetationMgmt.owner.BioAgents", "BioAgents", "BAID > 0")
# Execute CreateReplica
arcpy.CreateReplica_management(tableset, replica_type, output_workspace, replica_name, access_type, initial_sender, expand, reuse_schema, get_related)
Steve
