Hi all,I am trying to create a GIS data portal that allows users to select one out three diffent methods for data extraction.1) extract by graphic extent2) extract by extent of a county3) extract by unit (calfire)Here is my problem. I am using a switch statement that allow the users to select either one of these methods independently as shown on this thread.However, when I trigger the either one of the cases within my function by pushing on a download button. It seems like the GPtool cant access any input data for some reasons.errors I get for each of the functions described above :TypeError: Unable to get property 'geometry' of undefined or null reference TypeError: Unable to get property 'style' of undefined or null reference TypeError: Unable to get property 'style' of undefined or null reference
My code:var extractMethod = "extractByPoly"; var extractMethod = "extractByCounty"; var extractMethod = "extractByUnit"; function myFunction() { //var extractMethod = "extractByPoly"; //var extractMethod = "extractByCounty"; //var extractMethod = "extractByUnit"; switch (extractMethod) { default: //function extractData() { //get clip layers var clipLayers = []; if (registry.byId("layer1").get("checked")) { clipLayers.push("SRA"); } if (registry.byId("layer2").get("checked")) { clipLayers.push("Burn"); } if (clipLayers.length === 0 || map.graphics.graphics.length === 0) { alert("Select layers to extract and draw an area of interest."); return; } var featureSet = new FeatureSet(); var features = []; features.push(map.graphics.graphics[0]); featureSet.features = features; var params3 = { "Layers_to_Clip": clipLayers, "Area_of_Interest": featureSet, "Feature_Format": registry.byId("formatBox").get("value") }; domStyle.set(loading2, "display", "inline-block"); gp.submitJob(params3, completeCallback, statusCallback2, function (error) { alert(error); domStyle.set(loading2, "display", "none"); }); //} break; case "extractByCounty": //function executeQueryTask(county) { var clipLayers = []; if (registry.byId("layer1").get("checked")) { clipLayers.push("SRA"); } if (registry.byId("layer2").get("checked")) { clipLayers.push("Burn"); } if (clipLayers.length === 0) { alert("No layers to clip, please select a layer you would like to clip..."); return; } var county = document.getElementById("sel_county").value var unit = document.getElementById("sel_unit").value var queryTask = new QueryTask("http://webgisdevint1/arcgis/rest/services/Alex_Try/Counties/MapServer/0"); var query = new Query(); query.returnGeometry = true; query.outFields = ["NAME_PCASE"]; query.where = "NAME_PCASE = '" + county + "'"; query.outSpatialReference = map.spatialReference; queryTask.execute(query, function (featureSet) { var AOI = featureSet.features[0].geometry; var graphic = new Graphic(AOI); var features = []; features.push(graphic); var fSet = new FeatureSet(); fSet.features = features; var params = { "Layers_to_Clip": clipLayers, "Area_of_Interest": fSet, "Feature_Format": registry.byId("formatBox").get("value") }; domStyle.set(loading, "display", "inline-block"); gp.submitJob(params, completeCallback, statusCallback, function (error) { alert(error); domStyle.set(loading, "display", "none"); }); }); //} break; case "extractByUnit": //function executeQueryTask1(unit) { var clipLayers = []; if (registry.byId("layer1").get("checked")) { clipLayers.push("SRA"); } if (registry.byId("layer2").get("checked")) { clipLayers.push("Burn"); } if (clipLayers.length === 0) { alert("No layers to clip, please select a layer you would like to clip..."); return; } var unit = document.getElementById("sel_unit").value var queryTask = new QueryTask("http://webgisdevint1/arcgis/rest/services/Alex_Try/Layers/MapServer/1"); var query = new Query(); query.returnGeometry = true; query.outFields = ["UNITCODE"]; query.where = "UNITCODE = '" + unit + "'"; query.outSpatialReference = map.spatialReference; queryTask.execute(query, function (featureSet) { var AOI = featureSet.features[0].geometry; var graphic = new Graphic(AOI); var features = []; features.push(graphic); var fSet = new FeatureSet(); fSet.features = features; var params2 = { "Layers_to_Clip": clipLayers, "Area_of_Interest": fSet, "Feature_Format": registry.byId("formatBox").get("value") }; domStyle.set(loading1, "display", "inline-block"); gp.submitJob(params2, completeCallback, statusCallback1, function (error) { alert(error); domStyle.set(loading1, "display", "none"); }); }); //} } }
Any idea why I get these errors?
