Google and do some quick search on esri,I can not find a way to remove the selected layer directory,as far as I know,If I want to remove the selected layer in TOC,I have to search it in TOC and then reflect to MapControl.The code below show how I remove the selected layer.I hope someone can launch some ideal a better or easier way to do this:/// <summary>
/// Get selected layer name in TOC.
/// </summary>
/// <param name="tocControl"></param>
/// <returns></returns>
public static string GetSelectedLayerName(ESRI.ArcGIS.Controls.AxTOCControl tocControl) {
ESRI.ArcGIS.Controls.esriTOCControlItem item = new ESRI.ArcGIS.Controls.esriTOCControlItem();
ESRI.ArcGIS.Carto.IBasicMap map = new ESRI.ArcGIS.Carto.MapClass();
ESRI.ArcGIS.Carto.ILayer layer = new ESRI.ArcGIS.Carto.FeatureLayerClass();
object legendGroup = new object();
object index = new object();
tocControl.GetSelectedItem(ref item, ref map, ref layer, ref legendGroup, ref index);
if(item == ESRI.ArcGIS.Controls.esriTOCControlItem.esriTOCControlItemLayer) {
return layer.Name;
return null;
/// <summary>
/// Delete layer.
/// </summary>
 /// <param name="sender"></param>
 /// <param name="e"></param>
 private void btn_deleteLayer_Click(object sender, EventArgs e) {
string selectedLayer = GetSelectedLayerName();
for(int i = 0; i < map_main_con.LayerCount; i++) {
 if(map_main_con.get_Layer(i).Name == selectedLayer) {
 map_main_con.DeleteLayer(i);
break;
MessageBox.Show("Done");
Thanks very much.
