Hi, we have meet a terrible problem, We use SingleInstance mode in our project, when do some interactions in current module and then switch to other modules, the map is likely to be locked and deadly, can't be navigate and interact with the map. In the attached sample codes, selects features using SketchCreationMode.Rectangle and then tab to another do some interactions, the map will is likely to be locked and unoperational. sample codes are less the packages folder beacuse of the attach size limit, will you please test my codes and if any solution to solve this please do let us know. Thanks
