Hi
I am looking for a way to replace Null Values (-9999) with a set value in Model Builder. I have extracted values to points and want to replace the Null values with a set value. I have tried an iterator but that doesn't seem to work. With raster image I used Is Null and Con Null tool to replace the value. I am not to sure if this is possible for extract values from points. When I do this manually I go through edit mode and do a find and replace. But this is not work for Model Builder.
I was wondering if there is a script I could use or a way around this issue.
I need to replace the -9999 values with -13.54.
If anyone has any ideas, that would be great.
Thank
Jess
