Is there a way to view Socrata data on an ArcGIS Online map? I want to view the Socrata data as a live feed and not have to make a copy of the data on AGOL for it to work. The Socrata data is exposed as a .JSON file. Here is an example dataset: https://data.austintexas.gov/Government/Austin-Animal-Center-Found-Pets-Map/hye6-gvq2
And the example's rest endpoint is: https://data.austintexas.gov/resource/hye6-gvq2.json
Was also hoping to do this all through the AGOL interface and not have to use ESRI's javascript API to make this happen.
The reason I ask is, Socrata is the City of Austin's open data platform. I'm trying to come up with a means for the general ArcGIS Online users to incorporate datasets they discover on Socrata into the maps they are creating. These users usually have little to no programming experience so something through the AGOL interface is ideal.
Thanks for any help you can provide,
Andrew
