I am trying to add proxy information to my site and my JavaScript, but it's returning errors. I don't need these urls to be secure. The following is my code for my application and my proxy.config file for the application published at: maps.decaturil.gov/decaturPrint
App Code:
<!DOCTYPE html>
<html>
<head>
<title>Create a Map</title>
<meta http-equiv="content-type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/soria/soria.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
<style>
html, body, #mapDiv
padding:0;
margin:0;
height:100%;
width:100%;
#feedback
background: #fff;
border: 2px solid #666;
border-radius: 5px;
bottom: 20px;
color: #666;
font-family: arial;
height: auto;
left: 20px;
margin: 5px;
padding: 10px;
position: absolute;
width: 300px;
z-index: 40;
#feedback a
border-bottom: 1px solid #888;
color: #666;
text-decoration: none;
#feedback a:hover, #feedback a:active, #feedback a:visited {
border: none;
color: #666;
#note
padding: 0 0 10px 0;
#info
padding: 10px 0 0 0;
</style>
<script src="http://js.arcgis.com/3.11/"></script>
<script>
var map;
require(["esri/map", "esri/config",
"esri/arcgis/utils",
"esri/dijit/Print",
"esri/geometry/Extent",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/FeatureLayer",
"esri/tasks/GeometryService",
"esri/tasks/PrintTemplate",
"dojo/_base/array",
"dojo/dom",
"dojo/on",
"dojo/parser",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/domReady!"], function (Map, esriConfig, arcgisutils, Print, Extent,
ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
FeatureLayer, GeometryService, PrintTemplate, arrayUtils, dom, on, parser
/* The proxy comes before all references to web services */
/* Files required for security are proxy.config, web.config and proxy.ashx
- set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
(Roles are not required)
The proxy section is defined on the ESRI sample. I have included it as
part of the documentation reads that the measuring will not work.
I thought that might be important.
// Proxy Definition Begin
//identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
//If this null or not available the project and lengths operation will not work.
// Otherwise it will do a http post to the proxy.
esriConfig.defaults.io.proxyUrl = "proxy.ashx";
esriConfig.defaults.io.alwaysUseProxy = true;
// Proxy Definition End
// set custom extent
var initialExtent = new Extent({
"xmin": 777229.03,
"ymin": 1133467.92,
"xmax": 848340.14,
"ymax": 1185634.58,
"spatialReference": {
"wkid": 3435
// create map and set slider style to small
var map = new arcgisutils.createMap("mapDiv", {
showAttribution: false,
sliderStyle: "small",
extent: initialExtent
// add imagery
var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
map.addLayer(tiled);
// set operational layers
var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
// add operational layers
map.addLayer(operationalLayer);
// declare geometry service
esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
</script>
</head>
<body class="soria">
<div id="mapDiv"></div>
</body>
</html>
proxy.config file
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*"
mustMatch="false">
<serverUrls>
<!-- serverUrl options:
url = location of the ArcGIS Server, either specific URL or stem
matchAll = true to forward any request beginning with the url
token = (optional) token to include for secured service
dynamicToken = if true, gets token dynamically with username and
password stored in web.config file's appSettings section.
<serverUrl url="http://maps.decaturil.gov/arcgis/rest/services"
matchAll="true">
</serverUrl>
</serverUrls>
</ProxyConfig>
<!-- See https://github.com/Esri/resource-proxy for more information -->
