I've created annotation feature classes from Microstation DGN files and I need to add those to a series of mxd's using arcpy. I've been able to do that, but the layers are added as polygon features not as annotation features. I've dug around and found this solutionAnnotation classes not visible after adding an annotation layer , but it doesn't work for me. The feature class still adds as a polygon layer. Has anyone else run into this? Below is the relevant code.
<SPAN class="keyword token">for</SPAN> df <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListDataFrames<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> df<SPAN class="punctuation token">.</SPAN>name
<SPAN class="keyword token">if</SPAN> df<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">==</SPAN> <SPAN class="string token">"Layers"</SPAN><SPAN class="punctuation token">:</SPAN>
featclasses <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>County_Nam<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> featclasses
<SPAN class="keyword token">for</SPAN> fc <SPAN class="keyword token">in</SPAN> featclasses<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> fc
addLayer <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN>
reflayer <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListLayers<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"Private"</SPAN><SPAN class="punctuation token">,</SPAN>df<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">if</SPAN> fc <SPAN class="operator token">==</SPAN> County_Nam <SPAN class="operator token">+</SPAN> <SPAN class="string token">"_Anno_Ins"</SPAN><SPAN class="punctuation token">:</SPAN>
temp <SPAN class="operator token">=</SPAN> County_Nam <SPAN class="operator token">+</SPAN> <SPAN class="string token">"_Anno_Ins"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN>temp<SPAN class="punctuation token">)</SPAN>
annoLayer <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">(</SPAN>temp<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>AddLayer<SPAN class="punctuation token">(</SPAN>df<SPAN class="punctuation token">,</SPAN> annoLayer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"BOTTOM"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
