Hi all,today i'm experiencing new AGSLocalTiledLayer with tiled packages created by Desktop 10.1 beta2.If I choose a "classic" tiling scheme (ie Bing Maps,...) no problem to consume it with the iOS SDK.But, if I use a custom tiling scheme, nothing appear on the map 😞The problem is probably the spatialReference. When I unzip tile package, esriinfo/itemInfo.xml describe an extent in degrees and spatial ref name is RGF1993...which is in meters.In the cache description, all is ok I think (v101/Layers/conf.xml)If I change that to good coordinates it does not have any impact 😞After that, I try to log some layer properties and spatialReference has always an empty wkid and wkt when I load my tpk.Maybe it is a limitation on iOS ? If so can you add it in the documentation ? Maybe it is a bad practice in my code ?
AGSLocalTiledLayer *localTiledLayer = [[AGSLocalTiledLayer alloc] initWithName:@myTpk.tpk];
   NSLog(@%d,localTiledLayer.spatialReference.wkid);
   NSLog(@%@",localTiledLayer.spatialReference.wkt);
  Â
   //Add it to the map view
UIView<AGSLayerView>* lyr = [self.mapView addMapLayer:localTiledLayer withName:@TPK];
Maybe it is a bug in the iOS API ?Thank you for your reply !Tony
