Hi, I am new to esri api. I attempted to convert Point (x, y coordinates) into latitude and longitude in DMS via coordinatedFormatter. Something like below worked just fine.
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/geometry/coordinateFormatter"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"esri/Graphic"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>coordinateFormatter<SPAN class="punctuation token">,</SPAN>Point<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> x <SPAN class="operator token">=</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">118.80657463861</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> y <SPAN class="operator token">=</SPAN> <SPAN class="number token">34.0005930608889</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> point <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN>x<SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="template-string token"><SPAN class="string token">`@@ point </SPAN><SPAN class="interpolation token"><SPAN class="interpolation-punctuation punctuation token">${</SPAN>JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stringify</SPAN><SPAN class="punctuation token">(</SPAN>point<SPAN class="punctuation token">)</SPAN><SPAN class="interpolation-punctuation punctuation token">}</SPAN></SPAN><SPAN class="string token">`</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
coordinateFormatter<SPAN class="punctuation token">.</SPAN><SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> latlon <SPAN class="operator token">=</SPAN> coordinateFormatter<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toLatitudeLongitude</SPAN><SPAN class="punctuation token">(</SPAN>point<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dms"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="template-string token"><SPAN class="string token">`translated to latitude and longitude </SPAN><SPAN class="interpolation token"><SPAN class="interpolation-punctuation punctuation token">${</SPAN>JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stringify</SPAN><SPAN class="punctuation token">(</SPAN>latlon<SPAN class="punctuation token">)</SPAN><SPAN class="interpolation-punctuation punctuation token">}</SPAN></SPAN><SPAN class="string token">`</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>However when I tried to implement almost exact ^ logic into react + node.js environment. No matter what I tried, I was keep getting TypeError: Point is not a constructor error from console in chrome devtool. Here is the water down version of code.
<SPAN class="keyword token">import</SPAN> React <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'react'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">import</SPAN> <SPAN class="punctuation token">{</SPAN> loadModules <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'esri-loader'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">Test</SPAN> <SPAN class="keyword token">extends</SPAN> <SPAN class="token class-name">React<SPAN class="punctuation token">.</SPAN>Component</SPAN> <SPAN class="punctuation token">{</SPAN>
state <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
point<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
coordinateFormatter<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN>
<SPAN class="token function">componentDidMount</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">loadModules</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">'esri/geometry/coordinateFormatter'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'esri/geometry/Point'</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
Point
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> testPoint <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">118.80657463861</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">34.0005930608889</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setState</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
point<SPAN class="punctuation token">:</SPAN> testPoint
<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">catch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>err<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>err<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I tried different variations of adding properties to Point constructor but none worked out. I am desperate to identity what caused this error and how to rectify it. I'd appreciate your advice.
