I have a question for you all.
So, I want to compare between the dataset I have to check for each feature. My question here is what is "Input Base Features" and "Input Test Features" ? Why didn't ESRI put the Original Data vs the New Data instead ? It just helps to less confuse and claify.
I need to run MUID to check for compare to see if they both run the same name .
Thanks !
BTW, I am reading here Feature Compare—Help | ArcGIS for Desktop
So that helps but I want to know the difference between Input Base and Test Features ?
