Any ideas as to where to get help when something fails?
I configured the dynamic table to get some values from a master street table into the SiteAddressPoint table using the Validate attribute lookup method. It did not work.
I set the AA to debug and found that a couple of fields were not found. I have no idea where these fields are searched because both, the SiteAddressPoint and Master tables have the fields.
This is the configuration on the dynamic table:
TABLENAME: SiteAddressPoint
FIELDNAME: FULLNAME,PREDIR,STNAME,STTYPE,STTYPE1, STTYPE2, ALTUNITTYPE
VALUEMETHOD: VALIDATE_ATTRIBUTE_LOOKUP
VALUEINFO: MasterStreetName|FULLNAME, ROADPREDIR, ROADNAME, ROADTYPE, ROADTYPE1, ROADTYPE2, RAMP
Both sets of fields exist, FIELDNAME fields are from siteAddressPoint, and Fields from VALUEINFO exist in Master Street name.
The logfile states the rule was not processed:
Row Info
Row Number 8
TableName: SiteAddressPoint
FieldName: FULLNAME,PREDIR,STNAME,STTYPE,STTYPE1, STTYPE2, ALTUNITTYPE
ValueInfo: MasterStreetName|FULLNAME, ROADPREDIR, ROADNAME, ROADTYPE, ROADTYPE1, ROADTYPE2, RAMP
ValueMethod: VALIDATE_ATTRIBUTE_LOOKUP
On Create: 1
On Change: 1
Checking for Subtype Restriction <------ I do not know where this is
Field Name: Street Name was found at index: 12 <---- I am not sure where "Street Name is"
Field Name: QUADRANT was found at index: 43 <---- or quadrant
Field Name: STNAME was found at index: 44
Field Name: STTYPE was found at index: 45
Field Name: STTYPE1 was found at index: 54
STTYPE2 Field not found <------ These two fields exist in SiteAddressPoint
ALTUNITTYPE Field not found
Rule not processed
Any help would be appreciated.
