Hello,I'm running ArcGIS 9.3.1 and I have a shapefile with a period in the name, such as "Test.2.shp", which I can not use Describe to get the projection for. When I try to use gp.Describe('Test.2.shp').SpatialReference.Name, I get the error "RuntimeError: DescribeData: Method SpatialReference does not exist."Here is my code:import arcgisscripting, sys
gp = arcgisscripting.create(9.3)
gp.SetProduct("ArcInfo")
gp.workspace = 'D:/Temp'
print 'Test1.shp Name: '+gp.Describe('Test1.shp').Name
print 'Test.2.shp Name: '+gp.Describe('Test.2.shp').Name
print 'Test1 Prj: '+gp.Describe('Test1.shp').SpatialReference.Name
print 'Test.2 Prj: '+gp.Describe('Test.2.shp').SpatialReference.Name
And this is the result from the command line:Test1.shp Name: Test1.shp
Test.2.shp Name: Test.2.shp
Test1 Prj: NAD_1983_StatePlane_Illinois_East_FIPS_1201
File "D:\Temp\test.py", line 11, in <module>
Both Test1.shp and Test.2.shp have the same projection. Am I doing something wrong, or does anyone have a suggestion for me? I'd prefer not to have to rename the files.Thanks,Dan
