(SFV 1.3, sri 102xxx)Passing in extents from the database and using the following code to set the map extent. Whenever one of the extents are set, the viewer zooms in all the way.var ext:String = event.data.toString();
var extArray:Array = ext.split(" ");
var extent:Extent = new Extent(Number(extArray[0]), Number(extArray[1]), Number(extArray[2]), Number(extArray[3]));
map.extent = extent;
Sometimes the extent works, most of the time it is at the highest zoom level. What calculation is failing and where I can help correct it?
