How do I query a feature layer? My feature layer is about 150 points with attributes. I'd like to be able to have the user query these points by "Type".
I've had a look at this example: https://developers.arcgis.com/javascript/latest/sample-code/featurelayer-query/index.html As far as I can see I should be able to use it.
Based on the example, here's what I came up with using my own data. But it's not functioning.
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1,maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Query features <SPAN class="keyword token">from</SPAN> a FeatureLayer <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.9</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.9%2Fesri%2Fcss%2Fmain.css" target="_blank">https://js.arcgis.com/4.9/esri/css/main.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.9%2F" target="_blank">https://js.arcgis.com/4.9/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
html<SPAN class="punctuation token">,</SPAN>
body<SPAN class="punctuation token">,</SPAN>
#viewDiv <SPAN class="punctuation token">{</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
#infoDiv <SPAN class="punctuation token">{</SPAN>
background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> white<SPAN class="punctuation token">;</SPAN>
color<SPAN class="punctuation token">:</SPAN> black<SPAN class="punctuation token">;</SPAN>
padding<SPAN class="punctuation token">:</SPAN> 6px<SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> 400px<SPAN class="punctuation token">;</SPAN>
#results <SPAN class="punctuation token">{</SPAN>
font<SPAN class="operator token">-</SPAN>weight<SPAN class="punctuation token">:</SPAN> bolder<SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/geometryEngine"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Graphic"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>
Map<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN>
FeatureLayer<SPAN class="punctuation token">,</SPAN>
GraphicsLayer<SPAN class="punctuation token">,</SPAN>
geometryEngine<SPAN class="punctuation token">,</SPAN>
Graphic
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> attTypeSelect <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"attractions"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//attractions</SPAN>
<SPAN class="keyword token">var</SPAN> attractions <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fservices.arcgis.com%2FfGsbyIOAuxHnF97m%2Farcgis%2Frest%2Fservices%2FAttractions%2FFeatureServer%2F0%3Ftoken%3DkIhkvEGZO_-PPXgeZu2nYpHz_eXYZ1NZ9DGgX7CbRZsG9vic6BHNeOiiLw37TCoGgn22dNexnPmhppQk8YeXV3f0OxYcTC1YcMINIwcbcw_e8tEpKfdkjCLL3byL640Dil7J-izJUpOFIl7Wa1L6UpZ-xZbP1oA41jmhaOC_dha3PPvm-lwnFY6ZsAk5IIdub0_nimOM2IlTUTaER45elvCg3lfmy5BVodDkggLnWQY-60sg50jYQys-QSpzDFSShttps%3A%2F%2Fservices.arcgis.com%2FfGsbyIOAuxHnF97m%2Farcgis%2Frest%2Fservices%2FAttractions%2FFeatureServer%2F0%3Ftoken%3Dbrm_9OG_7AUlcufevjfLoiSCxxlcVN1g5n68z0G-L5L1gE22RKd_us2vNRlwNY1EwS0ci88AMo4Xu7Y90ScmkgC4KubpvN94IAAPMn1JdSEaDsNACutdsM0RCDxAUt6OJa5JDd3K53AI816rgB6QgMGaqNnR4A7-XNgfqKwfN9ygBw_P0uN_Mec_NPoKg19J_S91p9LwPuxjSGgYjPC6N6rJTsp206_z4Om7XtP_3uUaVHf6NRMDy4TdLMotUnxs" target="_blank">https://services.arcgis.com/fGsbyIOAuxHnF97m/arcgis/rest/services/Attractions/FeatureServer/0?token=kIhkvEGZO_-PPXgeZu2nYpHz_eXYZ1NZ9DGgX7CbRZsG9vic6BHNeOiiLw37TCoGgn22dNexnPmhppQk8YeXV3f0OxYcTC1YcMINIwcbcw_e8tEpKfdkjCLL3byL640Dil7J-izJUpOFIl7Wa1L6UpZ-xZbP1oA41jmhaOC_dha3PPvm-lwnFY6ZsAk5IIdub0_nimOM2IlTUTaER45elvCg3lfmy5BVodDkggLnWQY-60sg50jYQys-QSpzDFSShttps://services.arcgis.com/fGsbyIOAuxHnF97m/arcgis/rest/services/Attractions/FeatureServer/0?token=brm_9OG_7AUlcufevjfLoiSCxxlcVN1g5n68z0G-L5L1gE22RKd_us2vNRlwNY1EwS0ci88AMo4Xu7Y90ScmkgC4KubpvN94IAAPMn1JdSEaDsNACutdsM0RCDxAUt6OJa5JDd3K53AI816rgB6QgMGaqNnR4A7-XNgfqKwfN9ygBw_P0uN_Mec_NPoKg19J_S91p9LwPuxjSGgYjPC6N6rJTsp206_z4Om7XtP_3uUaVHf6NRMDy4TdLMotUnxs</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"attractions"</SPAN><SPAN class="punctuation token">,</SPAN>
visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//GraphicsLayer for desplaying results</SPAN>
<SPAN class="keyword token">var</SPAN> resultsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"dark-gray"</SPAN><SPAN class="punctuation token">,</SPAN>
layer<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"attractions"</SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">87.75188</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">41.23308</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"infoDiv"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//query all features from the attractions layer</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> attractions<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> query <SPAN class="operator token">=</SPAN> attractions<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> attractions<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>getValues<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>getUniqueValues<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>addToSelect<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// return an array of all the values in the</SPAN>
<SPAN class="comment token">// Type field of the attractions layer</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">getValues</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> features <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> values <SPAN class="operator token">=</SPAN> features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>Type<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> values<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// return an array of unique values in</SPAN>
<SPAN class="comment token">// the Type field of the attractions layer</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">getUniqueValues</SPAN><SPAN class="punctuation token">(</SPAN>values<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> uniqueValues <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
values<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> i<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>uniqueValues<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token"><</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="operator token">||</SPAN> uniqueValues<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">===</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">&&</SPAN>
<SPAN class="punctuation token">(</SPAN>item <SPAN class="operator token">!==</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
uniqueValues<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> uniqueValues<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Add the unique values to the attractions type</SPAN>
<SPAN class="comment token">// select element. This will allow the user</SPAN>
<SPAN class="comment token">// to filter attractions by type.</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">addToSelect</SPAN><SPAN class="punctuation token">(</SPAN>values<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
values<SPAN class="punctuation token">.</SPAN><SPAN class="token function">sort</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
values<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>value<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> option <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"option"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
option<SPAN class="punctuation token">.</SPAN>text <SPAN class="operator token">=</SPAN> value<SPAN class="punctuation token">;</SPAN>
attTypeSelect<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>option<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">setattractionsDefinitionExpression</SPAN><SPAN class="punctuation token">(</SPAN>attTypeSelect<SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// set the definition expression on the attractions</SPAN>
<SPAN class="comment token">// layer to reflect the selection of the user</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">setattractionsDefinitionExpression</SPAN><SPAN class="punctuation token">(</SPAN>newValue<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
attractions<SPAN class="punctuation token">.</SPAN>definitionExpression <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Type"</SPAN> <SPAN class="operator token">+</SPAN> newValue <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>attractions<SPAN class="punctuation token">.</SPAN>visible<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
attractions<SPAN class="punctuation token">.</SPAN>visible <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">queryForAtractionGeometries</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Get all the geometries of the attractions layer</SPAN>
<SPAN class="comment token">// the createQuery() method creates a query</SPAN>
<SPAN class="comment token">// object that respects the definitionExpression</SPAN>
<SPAN class="comment token">// of the layer</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">queryForAttractionGeometries</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> attractionsQuery <SPAN class="operator token">=</SPAN> attractions<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> attractions<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN>attractionsQuery<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
attractionsGeometries <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> feature<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> attractionsGeometries<SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"infoDiv"</SPAN><SPAN class="operator token">></SPAN>
Select attractions type<SPAN class="punctuation token">:</SPAN>
<SPAN class="operator token"><</SPAN>select id<SPAN class="operator token">=</SPAN><SPAN class="string token">"attractions"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>select<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
