How do i convert Easting and Northing to Latitude and Longitude using the JavaScript API?
I have a rest service which returns an array of objects, each object contains geometry x and y coordinates, i believe this is Easting and Northing
<SPAN class="keyword token">var</SPAN> items <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"attributes"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">18342</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"geometry"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"x"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">250067.50299999956</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"y"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">659477.8800000008</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I'm using the Point class to try and pin each coordinate to my map, but i believe this class requires latitude and longitude format: https://developers.arcgis.com/javascript/3/jsapi/point-amd.html
Using 3.28
thanks
