Im trying to come up with a way to conditionally delete some records in a table. For instance, i have variably shaped polygons that when spatially joined with a point feature class tend to result in excess points on the larger polygons. I would like to set up a definition query to select and eventually delete every other or even every 2 out of 3 rows IF (and only if) there are, say more than 10 occurrences of that record. Im trying to implement this in arcmap via a python/sql query. Im sure there is way to do this in the output file (.csv) but I would like to maintain the integrity of the data in arcmap prior to exporting it.
Any help on how to go about doing this?
