Not sure why this is throwing an error. ## Get un-processed features from XYAttachments_insp GUID_Lst = [row[0] for row in arcpy.da.SearchCursor(JU_Src,Srch_Fld)] UGuid = set(GUID_Lst) print UGuid edit = arcpy.da.Editor(Wrksp) for GUID in UGuid: edit.startOperation() edit.startEditing(True,True) GSel = "GOSYNC.DBO.Att_Join_Tmp.wm_ElementGUID = GOSYNC.DBO.XYAttachments_insp.wm_ElementGUID AND GOSYNC.DBO.XYAttachments_insp.wm_ElementGUID =" + "'"+str(GUID)+"'" arcpy.MakeQueryTable_management("'Database Connections\\GOSYNC_GOSYNC.sde\\GOSYNC.DBO.Joint_Use_Insp\\GOSYNC.DBO.Att_Join_Tmp';\ 'Database Connections\\GOSYNC_GOSYNC.sde\\GOSYNC.DBO.Joint_Use_Insp\\GOSYNC.DBO.XYAttachments_insp'", "QryCnt", "USE_KEY_FIELDS",\ "GOSYNC.DBO.Att_Join_Tmp.OBJECTID", "GOSYNC.DBO.XYAttachments_insp.wm_ElementGUID #; GOSYNC.DBO.Att_Join_Tmp.wm_ElementGUID #;GOSYNC.DBO.Att_Join_Tmp.Attachment_ID #",\ GSel) IDCnt = int(arcpy.GetCount_management("QryCnt").getOutput(0)) + 1 print IDCnt WH_Clause = "\"wm_ElementGUID\" = '"+ GUID+"'" with arcpy.da.UpdateCursor(JU_Src,[Upd_Fld],WH_Clause) as UpdCrsr: for Urow in UpdCrsr: ATT_ID = str(GUID) + "_A"+str(IDCnt) print ATT_ID print Urow Urow[0] = ATT_ID UpdCrsr.updateRow(Urow) IDCnt = IDCnt + 1 edit.stopOperation() edit.stopEditing(True) arcpy.Delete_management("QryCnt")Any help would be appreciated.
