I'm trying to create a radar loop of PNG images that are georeferenced using MapImage and MapImageLayer in version 3.29. From looking at the page here:
https://community.esri.com/thread/210261-overlay-georeferenced-image-with-arcgis-javascript-46
You can't do this in version 4 yet so I am trying 3.29.
The problem I have is that the imagery flickers:
http://tropicalatlantic.com/historical/radars/2019/dorian/bahamas/
I use MapImageLayer to add a layer. Then I use MapImage. I use addImage, and then removeImage image, to add and remove imagery in the loop. The problem is that before the new image shows, the old image is removed. Sometimes once everything has loaded it starts flickering less, but with over 1,000 images in the loop, it always flickers to some extent. I was looking for a way to determine if something is still being drawn and after the new image has been drawn, remove the old one. What I have tried hasn't worked so far.
Another alternative would be to create over a 1,000 layers and add an image to each one. Then control the opacity of each one as I loop through, with only the one I want currently visible, but that seems like it would probably crash with over 30 megabytes of images. I'll probably try that next though to see how it goes.
I can't use another method of serving the imagery. I have another project with radar imagery and it too will work the same, PNG images for which I have coordinates for the extent.
