I face limitation with the ArcGIS Runtime 10.1.1 samples "Add Shapefile" (issue is similar with "Add Raster").I have just changed the source code in order to load a Local Tiled Package and used my own blank MPK to load Shpaefile/Raster.When I run the sample application, if I try to load several Shapefiles, I always have the following Exception on the 4th file.It's like my Local Server can't handle more than 3 worker processes at the same time... ...
2013-04-12 12:09:24,821: INFO rid=31 'server' mpk3 - Request handled.
2013-04-12 12:09:24,852: INFO rid=32 'server' mpk - Request handled.
2013-04-12 12:09:25,055: INFO rid=33 'server' mpk2 - Request handled. -> Here we see that there are 3 localmapservice already loaded
2013-04-12 12:09:29,305: INFO rid=34 'server' AdminWebService - POST admin/createService -> Here I just select a 4th shapefile
java.lang.NullPointerException
at com.esri.map.Layer.setUrl(Unknown Source)
at com.esri.map.DynamicLayer.setUrl(Unknown Source)
at com.esri.map.DynamicLayer.<init>(Unknown Source)
at com.esri.map.ArcGISDynamicMapServiceLayer.<init>(Unknown Source)
at com.esri.client.samples.datasources.LocalShapefileApp.addShapefile(LocalShapefileApp.java:103)
at com.esri.client.samples.datasources.LocalShapefileApp.access$3(LocalShapefileApp.java:73)
at com.esri.client.samples.datasources.LocalShapefileApp$3.actionPerformed(LocalShapefileApp.java:247)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6505)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3321)
at java.awt.Component.processEvent(Component.java:6270)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:723)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:682)
at java.awt.EventQueue$3.run(EventQueue.java:680)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:696)
at java.awt.EventQueue$4.run(EventQueue.java:694)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:693)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:244)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:163)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:147)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:139)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:97)
2013-04-12 12:09:35,071: INFO rid= '' WebServer - Lost connection on port 50000
Stopping server -> I've closed the application from here
2013-04-12 12:09:37,790: INFO rid= '' WebServer - Lost connection on port 50000
2013-04-12 12:09:37,790: INFO rid=35 'server' AdminWebService - POST admin/shutdown?f=json
2013-04-12 12:09:37,790: INFO rid= 'server' ServerMain - Shutting down
2013-04-12 12:09:37,790: INFO rid= 'server' ServerMain - Terminating web services
2013-04-12 12:09:37,790: INFO rid= 'server' AdminWebService - Terminating service blankMap.mpk
2013-04-12 12:09:37,790: INFO rid= 'server' mpk_host - Terminate
2013-04-12 12:09:37,790: INFO rid= 'server' AdminWebService - Terminating service blankMap.mpk2
2013-04-12 12:09:37,790: INFO rid= 'server' mpk2_host - Terminate
2013-04-12 12:09:37,790: INFO rid= 'server' AdminWebService - Terminating service blankMap.mpk3
2013-04-12 12:09:37,790: INFO rid= 'server' mpk3_host - Terminate
2013-04-12 12:09:37,790: INFO rid= 'server' ServerMain - Waiting for 3 worker processes to exit. Timeout=10s.
2013-04-12 12:09:37,899: INFO rid= '' WebServer - Lost connection on port 50000
2013-04-12 12:09:37,899: INFO rid= 'server' ServerMain - Worker processes exited.
2013-04-12 12:09:37,899: INFO rid= 'server' ServerMain - Deleting data directory C:/Windows/Temp/arcgisruntime_6452
2013-04-12 12:09:37,899: INFO rid= 'server' ServerMain - 10 filesystem object(s) removed.
2013-04-12 12:09:37,899: INFO rid= 'server' ServerMain - Server process exiting.
Local server exited, code: 0
Exception occurs on addShapefile(LocalShapefileApp.java:103), and corresponds to :// set up a local dynamic layer
final ArcGISDynamicMapServiceLayer localDynamicLayer = new ArcGISDynamicMapServiceLayer(
localMapService.getUrlMapService());
I've checked for Local Server parameters in the runtime tool "Local Server Utility 10.1.1", but nothing there...Any ideas why I have limitations for 3 local map services ???
