What is the proper way to enumerate layers in MPK package generate from a personal geodatabase without using a MapView control? All the examples use the MapView or hard-code an index of the layer needed. Here is code (VB.NET):
Dim map As Esri.ArcGISRuntime.LocalServices.LocalFeatureService = _
Await Esri.ArcGISRuntime.LocalServices.LocalFeatureService.StartAsync(mpkPath)
Dim i As Integer = 0
Do While True
Dim sfTable As Esri.ArcGISRuntime.Data.ServiceFeatureTable = Nothing
Try
sfTable = Await Esri.ArcGISRuntime.Data.ServiceFeatureTable.OpenAsync(New Uri(map.UrlMapService & "/" & i))
Catch ex As Exception
sfTable = Nothing
End Try
If sfTable Is Nothing Then
Exit Do
End If
' Do something with sfTable
i += 1
Loop
Is this the proper way of enumerating until you get a 404 error when you're passed the last index ?
Thanks in advance,
Mark Oberg
