Hi, Is there a way to locate address location by only partially search text?I have tried the sample code (changed address Parameters):if the search text is for example "2011 MISSION ST" i get no results...how can i do this?public LocalGeocode() { InitializeComponent(); FindText.Text = "1455 MARKET ST, SAN FRANCISCO, CA 94103"; FindText.Items.Add("2011 MISSION ST, SAN FRANCISCO CA 94110"); FindText.Items.Add("820 BRYANT ST, SAN FRANCISCO CA 94103"); FindText.SelectedIndex = 0; _locationGraphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer; LocalGeocodeService.GetServiceAsync("..\\Data\\Locators\\SanFrancisco\\SanFranciscoLocator.gcpk", "SanFranciscoLocator", (gs) => { if (gs.Error != null) { MessageBox.Show(gs.Error.Message); } if (gs.Status == LocalServiceStatus.Running) { _localGeocodeService = gs; ExecuteButton.IsEnabled = true; DataContext = this; IsBusy = false; } }); } private void ExecuteButton_Click(object sender, RoutedEventArgs e) { IsBusy = true; var searchText = FindText.Text; Locator locatorTask = new Locator(_localGeocodeService.UrlGeocodeService); locatorTask.AddressToLocationsCompleted += (object sender1, AddressToLocationsEventArgs args) => { if (args.Results.Count > 0) { AddressCandidate bestCandidate = args.Results[0]; foreach (AddressCandidate candidate in args.Results) bestCandidate = (candidate.Score > bestCandidate.Score) ? candidate : bestCandidate; MapPoint geographicPoint = new MapPoint(bestCandidate.Location.X, bestCandidate.Location.Y, new SpatialReference(4326)); Graphic graphic = new Graphic() { Geometry = geographicPoint, Symbol = LayoutRoot.Resources["StrobeMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol }; _locationGraphicsLayer.Graphics.Clear(); _locationGraphicsLayer.Graphics.Add(graphic); IsBusy = false; } else { MessageBox.Show("No results found"); IsBusy = false; } }; locatorTask.Failed += (s2, e2) => { MessageBox.Show("Geocode failed with error: " + e2.Error.Message); }; AddressToLocationsParameters addressParameters = new AddressToLocationsParameters(); Dictionary<string, string> address = addressParameters.Address; //address.Add("Single Line Input", searchText); instead of this line i have tried searching foreach (var addressField in _localGeocodeService.AddressesFields) { address.Add(addressField.Name, searchText); } locatorTask.AddressToLocationsAsync(addressParameters); } }
