Our web map added with Bing and two dynamic map layers.
Here my problem is after some zoom when I change map option from Bing to dynamic It is taking minimum 1 minute time to load the map. And some times it is very faster also. See the code below.Where is the problem? Any Idea?Always bing map loading very quickly .Only loading time taking AltareeqEng and AltareeqArb .
I am very new in javascript and help is indeed
function createBasemapGallery() {
//AltareeqEng = document.getElementById('TxtAltareeqEng').value;
//AltareeqArb = document.getElementById('TxtAltareeqArb').value;
AltareeqEng = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapServer";
AltareeqArb = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapServer";
//Manually create a list of basemaps to display
var basemaps = [];
BingMapsRoad = new esri.dijit.Basemap({
layers: [new esri.dijit.BasemapLayer({
type: "BingMapsRoad"
title: "BingMaps-Road"
basemaps.push(BingMapsRoad);
BingMapsAerial = new esri.dijit.Basemap({
type: "BingMapsAerial"
title: "BingMaps-Aerial"
basemaps.push(BingMapsAerial);
BingMapsHybrid = new esri.dijit.Basemap({
type: "BingMapsHybrid"
title: "BingMaps-Aerial-Labels"
basemaps.push(BingMapsHybrid);
TareeqENG = new esri.dijit.Basemap({
layers: [new esri.layers.ArcGISDynamicMapServiceLayer(AltareeqEng)],
title: "Al-Tareeq(ENG)"
basemaps.push(TareeqENG);
TareeqARB = new esri.dijit.Basemap({
layers: [new esri.layers.ArcGISDynamicMapServiceLayer(AltareeqArb)],
title: "Al-Tareeq(AR)"
basemaps.push(TareeqARB);
basemapGallery = new esri.dijit.BasemapGallery({
showArcGISBasemaps: false,
basemaps: basemaps,
bingMapsKey: "ApQHaZPBoOEOX4-UAgLYcLYr74TJszVCtaCXe0Tij5mMpuUTWXegmUcs0qUonSg2",
map: map
graphicsLayer = new esri.layers.GraphicsLayer();
map.addLayer(graphicsLayer);
//BasemapGallery.startup isn't needed because we aren't using the default basemap, instead
//we are going to create a custom user interface to display the basemaps, in this case a menu.
dojo.forEach(basemapGallery.basemaps, function (basemap) {
//Add a menu item for each basemap, when the menu items are selected
dijit.byId("bingMenu").addChild(new dijit.MenuItem({
label: basemap.title,
onClick: dojo.hitch(this, function () {
this.basemapGallery.select(basemap.id);
