Running Python without ArcGis interface
Hi, I'm running a loop over network analysis (270x56 matrix). The loop is working much better now but I would like to know if there is a way to run a python code over ArcGis with out open the ArcMap interface.
What is more, I cannot run my code directly from the python shell and I always have to manually upload the layers that i need as inputs, load my code in the ArcGis python interface and the run it. Is it possible to upload and use layers using a python code?
Thanks in advance. Below you find a copy of my python code.
Best
J
# FIND THE ROUTES AND EXPORT
# Description:
# This script aims to find and save the best route from each starting
# point x to each destination point y, over the network of roads.
# to do this I follow these steps
# 1. Create master layer, input layers and the output base
# 2. loop over origin x and destination y:
# a. Create the stops
# b. Solve the route
# c. Select roads and municipalities and save them in output layers
# d. Clean master layers
# VERY IMPORTANT -> REMEMBER TO THE FILES IN THE WORKING AND OUTPUT FOLDERS
# PREABULE
# Declare: Folder Paths
path = "C:\Users\uctpjam\AnalysisDDRoutes111020\\"
# The path is the key local to change in order to run the same program over
# different folders.
pathWorking = path + "ToWork\\"
pathOutput = path + "Output\\"
# Declare: Network Analysis Locals
MRoute = "MasterRoute" # I can solve over one Make a route layer
inputLyr = MRoute + "/Routes"
NetLines = "vias_unificado"
Active_Net = "Roads/vias_unificado_ND" # Active network
hrch = "USE_HIERARCHY" # Declare Hierarchy
cost = "Length" # Cost variable#
op1 = "USE_INPUT_ORDER"
op2 = "PRESERVE_BOTH"
op3 = "NO_TIMEWINDOWS"
op4 = "ALLOW_UTURNS"
op5 = "TRUE_LINES_WITH_MEASURES"
# Declare: Program local variables
Org = "orgRoads"
Dest = "destRoads"
Stp = Org + ";" + Dest
mStop = "Stops_Master"
mpios = "wlMunicipios"
baseMpio = "routesMnpAll"
baseLine = "routesLineAll"
# Call the packages
import arcpy, os # Argis
from arcpy import env # Import environments
env.workspace = path
# 1. SET UP MAIN AND MASTER LAYERS
# Check out any necessary licenses
arcpy.CheckOutExtension("Network")
# Process: Make Route Layer
arcpy.MakeRouteLayer_na(Active_Net, MRoute, cost, op1, op2, op3, "", op4, "",hrch, "", op5, "")
# Process: Master Stop Layer
arcpy.CreateFeatureclass_management(pathWorking,mStop,"POINT",Org)
# Process: Municipalities Output
# Note: I'm having problems with the field names. What I'm doing is to create 2
# copies of the "Municipios" Layer, one empty one as master layer
# and one full as input layer.
arcpy.CreateFeatureclass_management(pathOutput,baseMpio,"POLYGON",mpios) # Master layer
# Process: Output Road Layer
arcpy.CreateFeatureclass_management(pathOutput,baseLine,"POLYLINE",NetLines) # Base
# Process: Add Field with the route name
LYR = [baseMpio, baseLine, NetLines, mpios]
for i in LYR:
arcpy.DeleteField_management(i,"routeCode")
arcpy.AddField_management(i,"routeCode","TEXT","#","#","#","#","NULLABLE","NON_REQUIRED","#")
# Process: Expression (core) to get the route layer
expression = "categoria(!routeCode!)"
# 2. FIND THE ROUTES - LOOP OVER ORIGIN/DESTINATIONS
for x in range(0,270):
for y in range(0,56):
# Declare Local Variables
selectOrg ="FID=" + str(x)
selectDest ="FID=" + str(y)
outRuta = "Route_"+str(x)+"_"+str(y)
rutaVar = "'" + outRuta + "'"
vLocal = "selecOrg, selectDest, outRuta, rutaVar"
# Process: Select Origin and Destination
arcpy.SelectLayerByAttribute_management(Org, "NEW_SELECTION", selectOrg)
arcpy.SelectLayerByAttribute_management(Dest, "NEW_SELECTION", selectDest)
# Process: Append the stops to Stop Master
arcpy.Append_management(Stp, mStop)
# Process: Add stops
arcpy.AddLocations_na(MRoute, "Stops", mStop, "Name Name #", "10000 Meters","","","","CLEAR")
# Process: Define the expression to get the route code
codeblock = """def categoria(routeCode):
if routeCode == ' ':
return outRuta"""
try:
# Process: Solve
arcpy.Solve_na(MRoute, "SKIP", "TERMINATE")
# Process: Select by location and create new layer with the municipalities
arcpy.SelectLayerByLocation_management(mpios,"INTERSECT",inputLyr,"#","NEW_SELECTION")
arcpy.Append_management(mpios, baseMpio)
# Process: Select by location and create new layer with the roads
arcpy.SelectLayerByLocation_management(NetLines,"INTERSECT",inputLyr,"#","NEW_SELECTION")
arcpy.Append_management(NetLines, baseLine)
# Process: Route code
arcpy.CalculateField_management(baseMpio,"routeCode",expression,"PYTHON_9.3",codeblock)
arcpy.CalculateField_management(baseLine,"routeCode",expression,"PYTHON_9.3",codeblock)
except:
print "Error -> " + outRuta +" doesn't exist"
# Process: Clear Master Layers
arcpy.DeleteFeatures_management(mStop)
del vLocal
del codeblock
