I have a field that has a domain. The domain description shows in the attribute table, but not in labels, where the coded value is displayed. I have the check box 'Insert fields with coded value description function' checked.
Details:
Code snip
lbl <SPAN class="operator token">=</SPAN> $feature<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"L4STRUCTURES.structure_name"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\n"</SPAN>
lbl <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> <SPAN class="string token">"Size: "</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="token function">Text</SPAN><SPAN class="punctuation token">(</SPAN>$feature<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"L4STRUCTURES.structure_size"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
lbl <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> <SPAN class="string token">"\n"</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="token function">round</SPAN><SPAN class="punctuation token">(</SPAN>$feature<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"L4STRUCTURES.lat"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">6</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">", "</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="token function">round</SPAN><SPAN class="punctuation token">(</SPAN>$feature<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"L4STRUCTURES.long"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">6</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\n"</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
ArcGIS Pro 2.2.1
L4STRUCTURES is a feature class residing on a client's ArcGIS server, and is joined to another feature class from the same source and a local table.
Any idea how to get the descriptions to display? Thanks.
