I am trying to set up a map on arcgis online that I will update daily. When I try to publish the map from mxd I get the warning that the estimated cache size is 26 GB. When I calculate it in the caching setting it is actually 1,3 GB, but this still results in a warning. Is there a way of reducing this size?
I understand that caching is less relevant if the layers are updated frequently, and I will on a daily basis. Should I then reduce the number of tiles? What is recommended?
Thanks in advance!
