I am trying to setup a script that runs the CCTV solution daily and pulls data from our SDE. I'm getting an error and I don't know if it's related to using the SDE data or something else.
RuntimeError: cannot open 'R:\GIS\User\Krystal_Phaneuf\ArcGIS_Pro_Projects\CCTV_Manager\CCTVResults_08122019.gdb\DOU.GXP_GISINSPECTION_TVW'
The process creates a table in CCTVResults_08122019.gdb, but the name does not contain the "DOU." I think that's being pulled from my SDE and it's somehow referencing that name?
I'm using ArcGIS Pro 2.4.1 and SDE 10.4.1 Oracle 12c.
Any help or suggestions is appreciated!
Krystal
Full Message:
Messages
Start Time: Monday, August 12, 2019 3:53:23 PM
Running script GenerateCCTVPipeFeatures...
ArcGIS Pro 2.4.1.19948
utilsolutions 2.2.2
A python error occurred.
EXCEPTION
File "C:\Users\kphaneuf\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone3\Lib\site-packages\utilsolutions\esri\helper.py", line 35, in wrapper
return func(*args, **kwargs)
File "C:\Users\kphaneuf\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone3\Lib\site-packages\utilsolutions\esri\gptools.py", line 910, in run
points, lines, defects,group_layer = p.save_to_disk(target_gdb=gdb,group_layer=group_layer)
File "C:\Users\kphaneuf\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone3\Lib\site-packages\utilsolutions\cctv\core.py", line 479, in save_to_disk
inspection_df, condition_df = self.process()
File "C:\Users\kphaneuf\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone3\Lib\site-packages\utilsolutions\cctv\core.py", line 362, in process
df = self.pipe_df()
File "C:\Users\kphaneuf\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone3\Lib\site-packages\utilsolutions\cctv\core.py", line 230, in pipe_df
pipe_ids = self.inspection_df()[self.inspection_fk].tolist()
File "C:\Users\kphaneuf\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone3\Lib\site-packages\utilsolutions\cctv\core.py", line 271, in inspection_df
with arcpy.da.SearchCursor(self._inspection_table, fields, where_clause=sql) as cursor:
Failed to execute (GenerateCCTVPipeFeatures).
Failed at Monday, August 12, 2019 3:56:09 PM (Elapsed Time: 2 minutes 45 seconds)
