I have created a few story maps and I am familiar with adding story maps inside of story maps, but what I am trying to do is use the process of having the same maps across all the tabs, but with an app. The Tabbed Story map will have each tab having different layers displayed (Pavement projects, capacity, Safety etc) simple enough with referencing a map. At the same time, I would like the functionality of the widgets to allow the user change the base map and which layers are displayed. I don't want to create a unique app for each tab. Is there a way to filter the display of the app for each tab, so you are only using one app for all the tabs? Also, there is a layer list widget, but can you choose which layers are displayed as an option for the user to turn on and off (i.e layers 1-6, but layers 1, 3, and 4 are for functionality and will never be turned off and just clutter the list. Thus the widget would preferably only show layers 1, 2, 5 and 6).
Thank you!
