My script is failing because I'm trying to output a feature class that has domains into memory. Is there any work around for this yet?
You can ignore all the other code its just line 10 that fails. It works with any other feature except ones that have a domain. I'm pretty sure that is why the script fails.
ERROR 000210: Cannot create output memory\queryResidentsBuildings
<SPAN class="comment token">#This "for loop" is used for preset layers in the APRX. </SPAN>
<SPAN class="keyword token">if</SPAN> li <SPAN class="operator token">!=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> item <SPAN class="keyword token">in</SPAN> li<SPAN class="punctuation token">:</SPAN>
q <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" "</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
w <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" "</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN>
w <SPAN class="operator token">=</SPAN> w<SPAN class="punctuation token">.</SPAN>strip<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\'"</SPAN><SPAN class="punctuation token">)</SPAN>
lyr <SPAN class="operator token">=</SPAN> mp<SPAN class="punctuation token">.</SPAN>listLayers<SPAN class="punctuation token">(</SPAN>q<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Buffering "</SPAN><SPAN class="operator token">+</SPAN> q <SPAN class="operator token">+</SPAN> <SPAN class="string token">"..."</SPAN> <SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>management<SPAN class="punctuation token">.</SPAN>SelectLayerByLocation<SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"INTERSECT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"AOI"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"200 Meters"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NOT_INVERT"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CopyFeatures_management<SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">,</SPAN>r<SPAN class="string token">"memory\query"</SPAN><SPAN class="operator token">+</SPAN> q<SPAN class="punctuation token">)</SPAN>
e <SPAN class="operator token">=</SPAN> q <SPAN class="operator token">+</SPAN> w<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" "</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+</SPAN> w<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" "</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>analysis<SPAN class="punctuation token">.</SPAN>Buffer<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"memory\query"</SPAN><SPAN class="operator token">+</SPAN> q<SPAN class="punctuation token">,</SPAN> e<SPAN class="operator token">+</SPAN> <SPAN class="string token">"_buffer"</SPAN> <SPAN class="punctuation token">,</SPAN> w<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"FULL"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ROUND"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ALL"</SPAN><SPAN class="punctuation token">,</SPAN> None<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"PLANAR"</SPAN><SPAN class="punctuation token">)</SPAN>
aprx <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CURRENT"</SPAN><SPAN class="punctuation token">)</SPAN>
mp <SPAN class="operator token">=</SPAN> aprx<SPAN class="punctuation token">.</SPAN>activeMap
mp<SPAN class="punctuation token">.</SPAN>addDataFromPath<SPAN class="punctuation token">(</SPAN>fgdb <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\"</SPAN> <SPAN class="operator token">+</SPAN> e <SPAN class="operator token">+</SPAN> <SPAN class="string token">"_buffer"</SPAN><SPAN class="punctuation token">)</SPAN>
aprx <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN>aprxloc<SPAN class="punctuation token">)</SPAN>
mp <SPAN class="operator token">=</SPAN> aprx<SPAN class="punctuation token">.</SPAN>listMaps<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Map"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
limerge<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>fgdb<SPAN class="punctuation token">,</SPAN>e<SPAN class="operator token">+</SPAN> <SPAN class="string token">"_buffer"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Thanks,
