I've created a custom featureLayer from a featureClass that's been created from some query results. I add it to the map and then used it to spin up a featureTable. The featureTable looks fine but I can't seem to get table records to sync with the map graphics.
When I select a feature from the table, the header says that one feature has been selected but the map doesn't pan, like in the samples and I get the following console error:
TypeError: Object doesn't support property or method 'emit' TypeError: Object doesn't support property or method 'emit'
at Anonymous function (http://js.arcgis.com/3.16/esri/dijit/FeatureTable.js:74:136)
If I choose "Center on Selection" from the Options menu I get an additional console error:
Error: FeatureLayer::_query - query contains one or more unsupported parameters
Can anyone point me to where I'm setting things up incorrectly?
var resultsLayerDefinition = {
"geometryType": queryResults[0].geometryType,
"fields": queryResults[0].fields
//Workaround. FeatureTable will not work with results directly.
//https://community.esri.com/thread/165943
var copyFeatures = dojo.map(allFeatures, function (feature) {
return new Graphic(feature.toJson());
var resultsFeatureClass = {
layerDefinition: resultsLayerDefinition,
featureSet: {
"features": copyFeatures,
this._resultsFeatureLayer = new FeatureLayer(resultsFeatureClass);
var renderer = new SimpleRenderer(this._pointSymbol);
this._resultsFeatureLayer.setRenderer(renderer);
this.map.addLayer(this._resultsFeatureLayer);
this._resultsAttributeTable = new FeatureTable({
"featureLayer" : this._resultsFeatureLayer,
"map" : this.map,
"syncSelection": true,
"zoomToSelection": true
}, 'attributeTable');
this._resultsAttributeTable.startup();I'm using JSAPI 3.16.
Thanks!
Jill
ETA: It seems that others have reported this issue: JSAPI Feature layer created from feature collection and the feature table.
