Please let me know if the below code is right or not. if it is wrong can you please correct it for me.
I changed the below code from the above titled book during learning Tutorial 1, which was titled "Use Python in the Label Expression dialog box". I am using ArcGIS 10.1 but the tutorial used ArcGIS 10.2.
This is the original code from the text book.
def FindLabel ( [OwnerName] 😞
rawName = [OwnerName]
commaNum = rawName.find(",")
formatName = rawName[commaNum+2:] + " " + rawName[:commaNum]
return formatName
When I run this above code I have this error "SyntaxError: invalid syntax (<string> , line 4"
Can you please let me know the right code to use.
I modify it to below code but still experience another error.
formatName = rawName(commaNum[2:]) + " " + rawName(commaNum[0:]
return formatName
Regards,
Jeremiah.
