I've got a point feature layer that I've added to the map from an offline SQLite geodatabase generated from a feature service. I've set up labeling on the layer with the placement properties set to use the value from a rotation field to rotate the text. The points are rotating fine from that same field, but the point labels stay horizontal. Is this something 100.5 API does not support or am I missing something here?
