I am working on Robert's Enhanced Search Widget. (I need to make it query 8 parcel layers at one button click)
First, I have a question for Robert, is it okay to modify your code for our usage?
Every time I changed some coding, I need to do the following:
1. close the command window
2. re-launch the startup.bat
3. In the new tab of http://xyz.xyz.local:3344/webappbuilder , Create a new application->, choose my basemap from arcgis online, add my widget to test. (If I use an existing application, I do not see the update. Even if I force the chrome browser by pressing Ctrl+F5.)
What is the right way of debugging applications? I am guessing it is the Chrome cache, but Ctrl+F5 did not clear cache.. I copied the URL to EDGE and it would not work.
Thank you!
