Hello, I want to implement the esri.dijit.TimeSlider . But when I click the button that shows the div that contains the TimeSlider and after played, my base map does not show the behavior that I wanted.
What I doing wrong?
My code is like
function initSlider() { try{ var timeSlider = new esri.dijit.TimeSlider({ style: "width: 100%;"
}, dojo.dom.byId("timeSliderDiv")); map.setTimeSlider(timeSlider);
var timeExtent = new esri.TimeExtent();
timeExtent.startTime = new Date("01/01/2015".replace(/(\d{2})-(\d{2})-(\d{4})/, "$2/$1/$3")); //new Date("01/01/2015 UTC"); timeExtent.endTime = new Date("08/31/2015".replace(/(\d{2})-(\d{2})-(\d{4})/, "$2/$1/$3")); //new Date("08/31/2015 UTC"); timeSlider.setThumbCount(2);
timeSlider.createTimeStopsByTimeInterval(timeExtent, 1, "esriTimeUnitsWeeks");
timeSlider.setThumbIndexes([0, 1]);
timeSlider.setThumbMovingRate(2000);
timeSlider.startup();
//add labels for every other time stop
var labels = dojo._base.array.map(timeSlider.timeStops, function (timeStop, i) { //if ( i % 2 === 0 ) { return timeStop.getUTCFullYear();
//} else { return "";
timeSlider.setLabels(labels);
timeSlider.on("time-extent-change", function (evt) { var startValString = evt.startTime.getUTCFullYear();
var endValString = evt.endTime.getUTCFullYear();
dojo.dom.byId("daterange").innerHTML = "<i>" + startValString + " and " + endValString + "<\/i>"; });
catch (e) { console.log("ExcepTion : initSlider : " + e); HideProgress();
My code button is :
time = dojo.connect(map, 'layers-add-result', initSlider);
