Welcome everyone.
I have some problems adding jMap to jPanel. Im pretty new at ArcGis Runtime and Java Programming language. I want to add simple map to the jPanel shown below(green colour). I used NetBeans to make gui and some code is generated automatically.
This is my code:
<code>
import com.esri.map.JMap;
import com.esri.map.MapOptions;
import gui.SimpleMap;
import java.awt.BorderLayout;
import java.util.logging.Level;
import java.util.logging.Logger;
import javax.swing.*;
* @author Wojtek
public class Main extends JFrame {
* Creates new form Main
public Main() throws Exception {
initComponents();
addMap();
@SuppressWarnings("unchecked")
// <editor-fold defaultstate="collapsed" desc="Generated Code">
private void initComponents() {
jSplitPane1 = new javax.swing.JSplitPane();
jPanel5 = new javax.swing.JPanel();
jLabel6 = new javax.swing.JLabel();
jTextField4 = new javax.swing.JTextField();
jLabel7 = new javax.swing.JLabel();
jTextField5 = new javax.swing.JTextField();
jLabel8 = new javax.swing.JLabel();
jTextField6 = new javax.swing.JTextField();
jLabel9 = new javax.swing.JLabel();
jLabel10 = new javax.swing.JLabel();
jPanel4 = new javax.swing.JPanel();
jTabbedPane1 = new javax.swing.JTabbedPane();
jPanel1 = new javax.swing.JPanel();
jPanel3 = new javax.swing.JPanel();
jLabel1 = new javax.swing.JLabel();
jTextField1 = new javax.swing.JTextField();
jLabel2 = new javax.swing.JLabel();
jTextField2 = new javax.swing.JTextField();
jLabel3 = new javax.swing.JLabel();
jTextField3 = new javax.swing.JTextField();
jLabel4 = new javax.swing.JLabel();
jLabel5 = new javax.swing.JLabel();
jLabel11 = new javax.swing.JLabel();
jTextField7 = new javax.swing.JTextField();
jLabel12 = new javax.swing.JLabel();
jTextField8 = new javax.swing.JTextField();
jLabel13 = new javax.swing.JLabel();
jTextField9 = new javax.swing.JTextField();
jLabel14 = new javax.swing.JLabel();
jButton1 = new javax.swing.JButton();
jPanel2 = new javax.swing.JPanel();
jLabel6.setText("Współrzędne WGS-84");
jTextField4.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(java.awt.event.ActionEvent evt) {
jTextField4ActionPerformed(evt);
jLabel7.setFont(new java.awt.Font("Tahoma", 0, 12)); // NOI18N
jLabel7.setText(" φ");
jTextField5.addActionListener(new java.awt.event.ActionListener() {
jTextField5ActionPerformed(evt);
jLabel8.setText("°");
jTextField6.addActionListener(new java.awt.event.ActionListener() {
jTextField6ActionPerformed(evt);
jLabel9.setText("'");
jLabel10.setText("\"");
javax.swing.GroupLayout jPanel5Layout = new javax.swing.GroupLayout(jPanel5);
jPanel5.setLayout(jPanel5Layout);
jPanel5Layout.setHorizontalGroup(
jPanel5Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(jPanel5Layout.createSequentialGroup()
.addGroup(jPanel5Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addContainerGap()
.addComponent(jLabel7)
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED)
.addComponent(jTextField4, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel8, javax.swing.GroupLayout.PREFERRED_SIZE, 5, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jTextField5, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel9)
.addComponent(jTextField6, javax.swing.GroupLayout.PREFERRED_SIZE, 35, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel10))
.addGap(75, 75, 75)
.addComponent(jLabel6)))
.addContainerGap(85, Short.MAX_VALUE))
jPanel5Layout.setVerticalGroup(
.addGap(23, 23, 23)
.addGroup(jPanel5Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING, false)
.addComponent(jLabel8, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
.addGap(3, 3, 3))
.addGroup(jPanel5Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
.addComponent(jTextField4, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel7, javax.swing.GroupLayout.PREFERRED_SIZE, 49, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jTextField5, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jTextField6, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel10)))
.addContainerGap(436, Short.MAX_VALUE))
javax.swing.GroupLayout jPanel4Layout = new javax.swing.GroupLayout(jPanel4);
jPanel4.setLayout(jPanel4Layout);
jPanel4Layout.setHorizontalGroup(
jPanel4Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGap(0, 796, Short.MAX_VALUE)
jPanel4Layout.setVerticalGroup(
.addGap(0, 0, Short.MAX_VALUE)
setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
jPanel1.addComponentListener(new java.awt.event.ComponentAdapter() {
public void componentShown(java.awt.event.ComponentEvent evt) {
jPanel1ComponentShown(evt);
jLabel1.setText("WGS-84 Coords");
jTextField1.addActionListener(new java.awt.event.ActionListener() {
jTextField1ActionPerformed(evt);
jLabel2.setFont(new java.awt.Font("Tahoma", 0, 12)); // NOI18N
jLabel2.setText(" φ");
jTextField2.addActionListener(new java.awt.event.ActionListener() {
jTextField2ActionPerformed(evt);
jLabel3.setText("°");
jTextField3.addActionListener(new java.awt.event.ActionListener() {
jTextField3ActionPerformed(evt);
jLabel4.setText("'");
jLabel5.setText("\"");
jLabel11.setFont(new java.awt.Font("Tahoma", 0, 12)); // NOI18N
jLabel11.setText("λ");
jTextField7.addActionListener(new java.awt.event.ActionListener() {
jTextField7ActionPerformed(evt);
jLabel12.setText("°");
jTextField8.addActionListener(new java.awt.event.ActionListener() {
jTextField8ActionPerformed(evt);
jLabel13.setText("'");
jTextField9.addActionListener(new java.awt.event.ActionListener() {
jTextField9ActionPerformed(evt);
jLabel14.setText("\"");
jButton1.setText("jButton1");
jButton1.addActionListener(new java.awt.event.ActionListener() {
jButton1ActionPerformed(evt);
javax.swing.GroupLayout jPanel3Layout = new javax.swing.GroupLayout(jPanel3);
jPanel3.setLayout(jPanel3Layout);
jPanel3Layout.setHorizontalGroup(
jPanel3Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(jPanel3Layout.createSequentialGroup()
.addContainerGap()
.addGroup(jPanel3Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(jPanel3Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.TRAILING)
.addComponent(jLabel11)
.addComponent(jTextField7, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel12, javax.swing.GroupLayout.PREFERRED_SIZE, 5, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jTextField8, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel13)
.addComponent(jTextField9, javax.swing.GroupLayout.PREFERRED_SIZE, 35, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel14))
.addComponent(jLabel2)
.addComponent(jLabel1)
.addComponent(jTextField1, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel3, javax.swing.GroupLayout.PREFERRED_SIZE, 5, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jTextField2, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel4)
.addComponent(jTextField3, javax.swing.GroupLayout.PREFERRED_SIZE, 35, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel5)))))
.addGap(86, 86, 86)
.addComponent(jButton1)))
.addContainerGap(14, Short.MAX_VALUE))
jPanel3Layout.setVerticalGroup(
.addGap(23, 23, 23)
.addComponent(jLabel1, javax.swing.GroupLayout.PREFERRED_SIZE, 14, javax.swing.GroupLayout.PREFERRED_SIZE)
.addGroup(jPanel3Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING, false)
.addComponent(jLabel3, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
.addGap(3, 3, 3))
.addGroup(jPanel3Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
.addComponent(jTextField1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel2, javax.swing.GroupLayout.PREFERRED_SIZE, 49, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jTextField2, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jTextField3, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel12, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
.addGap(3, 3, 3))
.addComponent(jTextField7, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel11, javax.swing.GroupLayout.PREFERRED_SIZE, 49, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jTextField8, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jTextField9, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel14)))
.addGap(35, 35, 35)
.addContainerGap(329, Short.MAX_VALUE))
javax.swing.GroupLayout jPanel1Layout = new javax.swing.GroupLayout(jPanel1);
jPanel1.setLayout(jPanel1Layout);
jPanel1Layout.setHorizontalGroup(
jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(javax.swing.GroupLayout.Alignment.TRAILING, jPanel1Layout.createSequentialGroup()
.addGap(0, 860, Short.MAX_VALUE)
.addComponent(jPanel3, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE))
jPanel1Layout.setVerticalGroup(
.addComponent(jPanel3, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
jTabbedPane1.addTab("tab1", jPanel1);
javax.swing.GroupLayout jPanel2Layout = new javax.swing.GroupLayout(jPanel2);
jPanel2.setLayout(jPanel2Layout);
jPanel2Layout.setHorizontalGroup(
jPanel2Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGap(0, 1045, Short.MAX_VALUE)
jPanel2Layout.setVerticalGroup(
.addGap(0, 528, Short.MAX_VALUE)
jTabbedPane1.addTab("tab2", jPanel2);
javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
getContentPane().setLayout(layout);
layout.setHorizontalGroup(
layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addComponent(jTabbedPane1)
layout.setVerticalGroup(
pack();
}// </editor-fold>
private void addMap() throws Exception {
jPanel1.add(createUI());
private void jTextField1ActionPerformed(java.awt.event.ActionEvent evt) {
// TODO add your handling code here:
private void jTextField2ActionPerformed(java.awt.event.ActionEvent evt) {
private void jTextField3ActionPerformed(java.awt.event.ActionEvent evt) {
private void jTextField4ActionPerformed(java.awt.event.ActionEvent evt) {
private void jTextField5ActionPerformed(java.awt.event.ActionEvent evt) {
private void jTextField6ActionPerformed(java.awt.event.ActionEvent evt) {
private void jTextField7ActionPerformed(java.awt.event.ActionEvent evt) {
private void jTextField8ActionPerformed(java.awt.event.ActionEvent evt) {
private void jTextField9ActionPerformed(java.awt.event.ActionEvent evt) {
private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) {
private void jPanel1ComponentShown(java.awt.event.ComponentEvent evt) {
public JComponent createUI() throws Exception {
JPanel contentPane = new JPanel(new BorderLayout());
MapOptions mapOptions = new MapOptions(MapOptions.MapType.TOPO, 41.9000, 12.5000, 12);
map = new JMap(mapOptions);
contentPane.add(map);
return contentPane;
* @param args the command line arguments
public static void main(String args[]) {
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
try {
new Main().setVisible(true);
} catch (Exception ex) {
Logger.getLogger(Main.class.getName()).log(Level.SEVERE, null, ex);
// Variables declaration - do not modify
private javax.swing.JButton jButton1;
private javax.swing.JLabel jLabel1;
private javax.swing.JLabel jLabel10;
private javax.swing.JLabel jLabel11;
private javax.swing.JLabel jLabel12;
private javax.swing.JLabel jLabel13;
private javax.swing.JLabel jLabel14;
private javax.swing.JLabel jLabel2;
private javax.swing.JLabel jLabel3;
private javax.swing.JLabel jLabel4;
private javax.swing.JLabel jLabel5;
private javax.swing.JLabel jLabel6;
private javax.swing.JLabel jLabel7;
private javax.swing.JLabel jLabel8;
private javax.swing.JLabel jLabel9;
private javax.swing.JPanel jPanel1;
private javax.swing.JPanel jPanel2;
private javax.swing.JPanel jPanel3;
private javax.swing.JPanel jPanel4;
private javax.swing.JPanel jPanel5;
private javax.swing.JSplitPane jSplitPane1;
private javax.swing.JTabbedPane jTabbedPane1;
private javax.swing.JTextField jTextField1;
private javax.swing.JTextField jTextField2;
private javax.swing.JTextField jTextField3;
private javax.swing.JTextField jTextField4;
private javax.swing.JTextField jTextField5;
private javax.swing.JTextField jTextField6;
private javax.swing.JTextField jTextField7;
private javax.swing.JTextField jTextField8;
private javax.swing.JTextField jTextField9;
// End of variables declaration
private JMap map;
</code>
