Hi,In the REST query operation you are able to filter the geometry to a point so that the query only takes place at that location. I want to be able to do the same with the javascript api so that I can return the results of a field of a polygon at a specific point. I don't want to use a map for this but just return the text of the field. I have tried to use this example and modify it but without any success.http://help.arcgis.com/en/webapi/javascript/arcgis/demos/query/query_nomap.htmlThis is probably due in large part to my lack of javascript knowledge! The plan is to pass in the XY location via url into the queryfilter which I believe I have working its just the actual query task that I am unsure about.So I have taken the same code as the 'no map' example above and just changed the query part (see below). I am sure I need to do something more with the geometry point but I can't find any examples in code.Any help with this would be much appreciated!ThanksCameron //build query task myQueryTask = new esri.tasks.QueryTask("http://thgistest01/ArcGIS/rest/services/PollingDistrict/MapServer/1"); //Can listen for onComplete event to process results or can use the callback option in the queryTask.execute method. //dojo.connect(queryTask, "onComplete", showResults); //build query filter myQuery = new esri.tasks.Query(); new esri.geometry.Point ([x,y], new esri.SpatialReference({ wkid: sr })); mQuery.returnGeometry = "true"; myQuery.outFields = ["Polling_Station_UPRN", "District_Code"]; myQueryTask.execute(myQuery,showResults);
