Helllo,Today I've tried to modify the TOC provided by nliu ( http://www.arcgis.com/home/item.html?id=9b6280a6bfb0430f8d1ebc969276b109 ). The basic features are working, but I would like to add some parts.I would like to start with simple feature like adding a scalebar and OverviewMap, which I've thought isn't too hard. Unfortunetely I'm not able to get it work ðFrom my understanding I have to add the following (red marked):
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<title>TOC</title>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css" />
<link rel="stylesheet" type="text/css" href="http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs/css/agsjs.css" />
<style>
html, body {
height: 98%;
width: 98%;
margin: 0;
padding: 5px;
font-family: helvetica, arial, sans-serif;
font-size: 90%;
#leftPane {
width: 280px;
overflow: auto
/* this line hide layers when out of scale for the inline TOC */
.agsjsTOCOutOfScale {
/* display: none;*/
</style>
<script type="text/javascript">
var djConfig = {
parseOnLoad: false,
packages: [{
"name": "agsjs",
//if you want to host on your own server, download from
//http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/
// and put in folders then use path like:
//"location": location.pathname.replace(/\/[^/]+$/, '') + '/../src/agsjs'
// use /src/ for debug and /build/ for production.
// you can also use online version using the following location,
// however please noted googlecode.com is not a true CDN and is not fast and may not be available.
// also, it is recommended to use a particular version from /tags/agsjs/<version>/
// in a production app to avoid unexpected results.
//"location": "http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.06/build/agsjs"
//"location": "http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs"
//"location": "http://gmaps-utility-gis.googlecode.com/svn/trunk/agsjs/build/agsjs"
</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/">
</script>
var map, toc, dynaLayer1, dynaLayer2, featLayer1;
require(["dojo/_base/connect", "dojo/parser", "agsjs/dijit/TOC", "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"esri/map", "esri/dijit/Scalebar", "esri/dijit/OverviewMap", "esri/layers/FeatureLayer",
"dojo/fx", "dojo/domReady!"],
function(Scalebar, OverviewMap, connect, parser, TOC) {
// call the parser to create the dijit layout dijits
parser.parse(); // note djConfig.parseOnLoad = false;
var initialExtent = new esri.geometry.Extent({
xmin: -9549126.170705408,
ymin: 4612089.574063576,
xmax: -9542304.165930964,
ymax: 4617851.015070564,
"spatialReference": {
"wkid": 102100
map = new esri.Map("map", {
extent: initialExtent
//new scalebar
var scalebar = new Scalebar({
map: map,
scalebarUnit: "dual"
//new Overviewmap
var overviewMapDijit = new OverviewMap({
map: map,
visible: true
overviewMapDijit.startup();
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
map.addLayer(basemap);
dynaLayer1 = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyOperationalLayers/MapServer", {
opacity: 0.8
featLayer1 = new esri.layers.FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/1", {
mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
outFields: ["POP07_SQMI"] //,
featLayer1.setDefinitionExpression("STCOFIPS='21111'"); //Louisville, KY
var h = dojo.connect(map, 'onLayersAddResult', function(results) {
// overwrite the default visibility of service.
// TOC will honor the overwritten value.
dynaLayer1.setVisibleLayers([2, 5, 8, 11]);
try {
toc = new agsjs.dijit.TOC({
map: map,
layerInfos: [{
layer: featLayer1,
title: "FeatureLayer1"
layer: dynaLayer1,
title: "DynamicMapServiceLayer1"
// collapsed: false, // whether this root layer should be collapsed initially, default false.
//slider: false // whether to display a transparency slider.
}, 'tocDiv');
toc.startup();
dojo.connect(toc, 'onLoad', function() {
if (console) console.log('TOC loaded');
dojo.byId("FindNodeByLayer").disabled = false;
dojo.disconnect(h);
} catch (e) {
alert(e);
map.addLayers([dynaLayer1, featLayer1]);
//resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in
//the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_guidelines.htm
var resizeTimer;
dojo.connect(map, 'onLoad', function(theMap) {
dojo.connect(dijit.byId('map'), 'resize', function() { //resize the map if the div is resized
clearTimeout(resizeTimer);
resizeTimer = setTimeout(function() {
map.resize();
map.reposition();
}, 500);
</script>
</head>
<body class="claro">
<div id="content" data-dojo-type="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
<div id="header" data-dojo-type="dijit.layout.ContentPane" region="top">
<div>
Header
</div>
</div>
<div data-dojo-type="dijit.layout.ContentPane" id="leftPane" region="left" splitter="true">
<div data-dojo-type="dijit.layout.AccordionContainer" style="height: 300px;">
<div data-dojo-type="dijit.layout.ContentPane" title="TOC" selected="true">
<div id="tocDiv"></div>
</div>
</div>
</div>
<div id="map" data-dojo-type="dijit.layout.ContentPane" region="center"></div>
</body>
</html>
With these modifications I get the the following error and I have no idea, what could be wrong.Uncaught TypeError: Object function (){var a=arguments,args=a,a0=a[0],f,i,m,l=_2e8.length,_2ea;if(!(this instanceof a.callee)){return _2eb(a);}if(_2e9&&(a0&&a0.preamble||this.preamble)){_2ea=new Array(_2e8.length);_2ea[0]=a;for(i=0;;){a0=a[0];if(a0){f=a0.preamble;if(f){a=f.apply(this,a)||a;}}f=_2e8.prototype;f=f.hasOwnProperty("preamble")&&f.preamble;if(f){a=f.apply(this,a)||a;}if(++i==l){break;}_2ea=a;}}for(i=l-1;i>=0;--i){f=_2e8;m=f._meta;f=m?m.ctor:f;if(f){f.apply(this,_2ea?_2ea:a);}}f=this.postscript;if(f){f.apply(this,args);}} has no method 'parse' Would be awesome, if someone could help me.Thanks,Dominik
