I have a layer with over 250,000+ features, and I want to update all the attribute data using ArcObjects and C#. I have written the code below and it takes around 3 hours to perform the update. Can you suggest whether the code below is efficient enough and any suggestion regarding the delta tables please?
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">updateWithCursor</SPAN><SPAN class="punctuation token">(</SPAN>IWorkspace workspace<SPAN class="punctuation token">,</SPAN> IFeatureClass featureClass<SPAN class="punctuation token">,</SPAN> List<SPAN class="operator token"><</SPAN>Update<SPAN class="operator token">></SPAN> updateList<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">using</SPAN> <SPAN class="punctuation token">(</SPAN>ComReleaser comReleaser <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ComReleaser</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
IWorkspaceEdit workspaceEdit <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>IWorkspaceEdit<SPAN class="punctuation token">)</SPAN>workspace<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Start an edit session</SPAN>
workspaceEdit<SPAN class="punctuation token">.</SPAN><SPAN class="token function">StartEditing</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Start an edit operation</SPAN>
workspaceEdit<SPAN class="punctuation token">.</SPAN><SPAN class="token function">StartEditOperation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Use IFeatureClass.Search to create a search cursor.</SPAN>
IFeatureCursor searchCursor <SPAN class="operator token">=</SPAN> featureClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Search</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
comReleaser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ManageLifetime</SPAN><SPAN class="punctuation token">(</SPAN>searchCursor<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Find the positions of the fields used to get and set values.</SPAN>
<SPAN class="keyword token">int</SPAN> idIndex <SPAN class="operator token">=</SPAN> featureClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FindField</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ID"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">int</SPAN> serialIndex <SPAN class="operator token">=</SPAN> featureClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FindField</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"SERIAL"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">int</SPAN> cityIndex <SPAN class="operator token">=</SPAN> featureClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FindField</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CITY"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">int</SPAN> updateDateIndex <SPAN class="operator token">=</SPAN> featureClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FindField</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"UPDATEDATE"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">int</SPAN> counter <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
IFeature feature <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">while</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>feature <SPAN class="operator token">=</SPAN> searchCursor<SPAN class="punctuation token">.</SPAN><SPAN class="token function">NextFeature</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">string</SPAN> searchValue <SPAN class="operator token">=</SPAN> feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">get_Value</SPAN><SPAN class="punctuation token">(</SPAN>idIndex<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">ToString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>searchValue <SPAN class="operator token">!=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
Update upd <SPAN class="operator token">=</SPAN> updateList<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SingleOrDefault</SPAN><SPAN class="punctuation token">(</SPAN>x <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> x<SPAN class="punctuation token">.</SPAN>id <SPAN class="operator token">==</SPAN> searchValue<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>upd <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">set_Value</SPAN><SPAN class="punctuation token">(</SPAN>serialIndex <SPAN class="punctuation token">,</SPAN> upd<SPAN class="punctuation token">.</SPAN>serialNo<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">set_Value</SPAN><SPAN class="punctuation token">(</SPAN>cityIndex <SPAN class="punctuation token">,</SPAN> upd<SPAN class="punctuation token">.</SPAN>city<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">set_Value</SPAN><SPAN class="punctuation token">(</SPAN>updateDateIndex<SPAN class="punctuation token">,</SPAN> DateTime<SPAN class="punctuation token">.</SPAN>Now<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Store</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
Console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">WriteLine</SPAN><SPAN class="punctuation token">(</SPAN>counter<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
workspaceEdit<SPAN class="punctuation token">.</SPAN><SPAN class="token function">StopEditOperation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Stop the edit session. The saveEdits parameter indicates the edit session</SPAN>
<SPAN class="comment token">// will be committed.</SPAN>
workspaceEdit<SPAN class="punctuation token">.</SPAN><SPAN class="token function">StopEditing</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
