Hello all, I have perhaps an odd issue with regards to the Kernel Interpolation with Barriers (KIB) prediction method using Python (2.7) and ArcGIS 10.1.
First, using the Geostatistical Analyst wizard to perform the KIB, or Kernel Smoothing as it is referred to in the wizard, works fine and dandy. However, I want to move the KIB from the wizard into a python script so I can automate it for ~100 maps.
First, here are some parameters I use and want to apply from the wizard: Function=Exponential; Surface Type=Prediction; Bandwidth=1000; Smoothing Factor=0.2; and Radius=8000.
The link for the method is here: Kernel Interpolation With Barriers—Help | ArcGIS Desktop
The issue is that the KIB does not have a place to put the Smoothing and Radius (Search Neighborhood) information into the python script. I tried to run the script without it but I get this error:
ERROR 040008: Input value is out of range.
Failed to execute (KernelInterpolationWithBarriers).
I also tried to run the tool from within ArcMap but it also does not have a spot to input the search neighborhood.
I tried to figure out a way to include the Search Neighborhood environment in the script but I haven't found a way.
Does anyone have a solution to this or any feedback?
Thank you!
