I have a Python GP tool on our Arc GIS Server that generates a report based on a polygon drawn on a web map. I have a query that sorts up to the top 15 cities in the region by population and creates a temporary shapefile of these cities. Everything works fine until I have a small enough region that only has one populated city. I get this error from the server logs:
An invalid SQL statement was used. An invalid SQL statement was used. The Project method cannot do a datum transformation. Failed to execute (FeatureClassToFeatureClass).
I do not get this error if there are two or more populated cites in the region. Here is the Python snippet with the query. It's set to skip the temporary shapefile creation if there are no cities in the region.
cities <SPAN class="operator token">=</SPAN> temp_path <SPAN class="operator token">+</SPAN> region_name <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\"</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"cities.shp"</SPAN>
values <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>cities<SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
top_cities <SPAN class="operator token">=</SPAN> sorted<SPAN class="punctuation token">(</SPAN>values<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">15</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token">#adjust max rows count </SPAN>
query <SPAN class="operator token">=</SPAN> <SPAN class="string token">"\"{0}\" in {1}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">,</SPAN> tuple<SPAN class="punctuation token">(</SPAN>top_cities<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
check_list <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>cities<SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">for</SPAN> shapefile <SPAN class="keyword token">in</SPAN> check_list<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetCount_management<SPAN class="punctuation token">(</SPAN>shapefile<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">!=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>FeatureClassToFeatureClass_conversion<SPAN class="punctuation token">(</SPAN>cities<SPAN class="punctuation token">,</SPAN>temp_path <SPAN class="operator token">+</SPAN> region_name<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"pop.shp"</SPAN><SPAN class="punctuation token">,</SPAN>query<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">continue</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
