Problems Adding Graphics to a Feature Layer using applyEdits
I'm attempting to add a Graphic to a FeatureLayer. Whenever I do, the graphic gets added, but then a Type Error pops up. Neither the success callback nor the error callback are being triggered. The error is propagating up to a higher calling function which checks for intersections.
If I add the Graphic through the .add function (instead of applyEdits) it will add fine, but then it won't assign an object ID.
The error reads: "Type Error: Cannot read property "name" of null". There is no name property for the graphic.
The function that checks for intersection (where the error is bubbling up to):
[PHP]
intersectByGeometryService: function(result){
// Ext.Msg.alert('Added a graphic to the layer');
var resultGeometry = result.geometry;
var resultOID = result.attributes.valueOf('Object ID');
var layer = result.getLayer();
// Loop through the graphics of the layer, snagging the geometries of any that are there into an array.
var geometries = new Array();
for(var i = 0; i < layer.graphics.length; i++){
if(resultOID != layer.graphics.attributes.valueOf('Object ID')){
geometries.push(layer.graphics.geometry);
// var geometries = dojo.map(layer.graphics, function(feature){
// if(resultOID != feature.attributes.valueOf('Object ID')){
// return feature.geometry;
this.geometryService.intersect(geometries, resultGeometry, this.highlightIntersections,
function(err){
Ext.Msg.alert('Error occurred when checking for intersection: ' + err); // error propagates to here
[/PHP]
The function where I add the Graphics:
[PHP]
highlightIntersections: function(geometries){
// When this function is called from intersection calculations, this refers to Window.
var emp = Ext.getCmp('editormappanel');
for(var i = 0; i < geometries.length; i++){
// var symbol = new esri.symbol.SimpleFillSymbol({
// type : "esriSFS",
// style : "esriSFSSolid",
// color : [255, 0, 0, 255],
// outline : {
// type : "esriSLS",
// style : "esriSLSSolid",
// color : [255, 194, 0, 255],
// width : 2
var attributes = {name: 'composite value', type: 0, description: 'Intersection'};
var graphic = new esri.Graphic(geometries, null, attributes);
emp.compositelayer.applyEdits([graphic], null, null, function(adds, updates, deletes){
Ext.Msg.alert('Composite layer update successful');
}, function(err){
Ext.Msg.alert('Composite layer update failed: ' + err);
//this.map.graphics.add(new esri.Graphic(geometries, symbol));
[/PHP]
