I try to undo / redo the edit vertex using undomanager.
Graphic objects are tested. But I do not know what to do Edit vertex undo / redo.
Is it possible the vertex undo / redo?
I looked to find many examples have not found the answer.
i`m korean beginner programmer. help me~ T.T
function initEditing(evt) {
console.log("initEditing", evt);
var currentLayer = null;
var layers = arrayUtils.map(evt.layers, function(result) {
return result.layer;
console.log("result ==== "+result);
console.log("layers", layers);
editToolbar = new Edit(map);
editToolbar.on("deactivate", function(evt) {
console.log("deactivate !!!! ");
currentLayer.applyEdits(null, [evt.graphic], null);
arrayUtils.forEach(layers, function(layer) {
var editingEnabled = false;
layer.on("dbl-click", function(evt) {
event.stop(evt);
if (editingEnabled === false) {
editingEnabled = true;
editToolbar.activate(Edit.EDIT_VERTICES , evt.graphic);
pre_evt = evt.graphic;
editToolbar.on("vertex-move-stop", function(evt){
console.log("vertex-move-stop~");
g_evt = evt;
console.log("evt.transform ===== " +evt.transform);
var operation = new esri.dijit.editing.Update({
featureLayer : landusePointLayer,
preUpdatedGraphics:pre_evt,
postUpdatedGraphics: evt.graphic
var operation = new CustomOperation.Add({
graphicsLayer: pre_evt._graphicsLayer,
addedGraphic: evt.graphic
undoManager.add(operation);
console.log("operation ======== ",operation);
console.log("dbl-click & eidt true");
} else {
currentLayer = this;
editToolbar.deactivate();
console.log("dbl-click & eidt false ");
