With a client, I am currently using a couple of FGDB in an ArcGIS 10.8 environment to edit and publish several small town water and sewer datasets. Normally I VPN into their network and edit data through a Desktop on a network machine.
What I would like to do is access the data from this client through a published web map with editing capabilities using ArcGIS Pro, so as to access the network utility tools. I have read that this can not be done with the data in a FGDB as the data needs to be in an Enterprise database (SQL). A multi user environment would be nice and help, but not critical in this instance.
Soooooo, my question is "can SQL Express be used as the Enterprise database?" If so, are there any tricks, potholes or other issues that should be considered?
James Armstrong
